Go Back   Automotive Forums Car Chat > Honda > RSX
Old 11-01-2005, 10:52 AM
lizard200 lizard200 is offline
Question Alignment after lowering kit.
Hello I have bought new tires for my RSX-S. I thought I would get a new 4 wheels alignment. My car was lowered before. Does that change alignment specs or they stay to the original specs. Just the note: the car handles terrible now since the new alignment? I thought with new tires it will handles like a dream! Any ideas, suggestions?
Thanks in advance...
2002 RSX-S Black
Old 11-01-2005, 04:19 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
Re: Alignment after lowering kit.
Did you adjust the camber at all?
I've got a fever. And the only prescription is more cowbell...
Old 11-01-2005, 04:44 PM
crazy_canuck crazy_canuck is offline
How much was it lowered? What was it lowered on?
In most cases the camber will need to be adjusted.
Old 11-02-2005, 07:10 AM
Re: Re: Alignment after lowering kit.
The Eibach springs were installed plus, Eibach - Alignment Kit. It was done before I bought the car. Car was okay before alignment, now it is done to a factory specs. I probably shouldn't of touched it! They did 2 alignment so far but it keeps going out wack. Pulles to the left.
Front pretty much stayed the same. Rear left Camber changed from -1.2 to -0.8, Toe 0.25 to 0.09. Right rear Camber changed from -0.5 to -0.8,
Toe 0.33 to 0.11. Rear Cross Camber from -0.7 to 0.0. Total toe from 0.58 to 0.20, Thrust angle from -0.04 to -0.01.
Please let me know if you need more infor on print out reading?
2002 RSX-S Black
