Old 11-01-2005, 08:44 AM
grindking134 grindking134 is offline
New DMAX Diesel Engine
With out any luck through google I came here. Anybody Know the 0-60 time for a 2500HD DMAX.
Also with the new DMAX engine that produces 360 HP and 650 pounds of Tq was there any changes to the engine or did they just tune it different. Heres a link to there engine optsions everything looks the same.
http://www.chevrolet.com/silverado/specifications/
Sorry you have to click engine and it shows both on bottom the LLY and LBZ
Thanks for your help
Old 11-01-2005, 12:46 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: New DMAX Diesel Engine
Must be... I was looking to see if the compression was different on it or something, but they are identical
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 11-01-2005, 07:00 PM
bigbadram51 bigbadram51 is offline
Re: Re: New DMAX Diesel Engine
As for the 0-60 times I cannot help there. I have driven the new DMAX, its a beast, it only had 7 miles on it so it will only get stronger, after about 1000 rpm it pulls as hard as my buddy's SS, pulls way harder than my parents 05 powerstroke.
Here is where the power difference comes from
The Duramax 6600's horsepower and torque increase and emissions reduction are enabled by a strengthened iron cylinder block and a lower compression ratio. The lower compression reduces stress on the engine by reducing the peak cylinder firing pressure. This, in turn, allows more fuel to be burned - more fuel means more power - while the lower compression helps reduce NOx emissions. Lower compression also helps reduce noise and vibration, making the all variants of the 6600 a quieter and smoother engine.
Here is the link to a great article
http://www.thedieselpage.com/duramax...ewsrelease.htm
Once I find a new Dmax with the options I want, im trading in the 1500
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 11-01-2005, 07:52 PM
thanks so there is actual changes to it besides them just tuning it differnt
Old 11-01-2005, 08:03 PM
Moose is loose Moose is loose is offline
Don't forget it is "detuned" in 1st and 2nd gear (with the Allison) so as not to scatter that expensive little tranny down the highway. The Allison is only rated at 550 lbs. of Tq. The HP/TQ rating is what the engine actually is dyno'd at, not what it will dyno off the dealer lot with a truck around it. The friends I have that have driven the new DMax (dealers) say it feels identical, and only slightly quicker on the interstate when in the highest gears. Detuning the engine to compensate for the trans just sucks.
Old 11-01-2005, 08:21 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
The 06 D Max has some internal changes including new heads and a lower compression ratio.
Fuel pressure has been increased also.
The LBZ DMax will be coming out..the only change is calibrations to raise the HP up 50 and the Torque up 45 more.
Add the 6 speed Allison and its a sweet ride
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
