Old 10-31-2005, 11:48 PM
Harbinger225 Harbinger225 is offline
Headers... tell me which set to buy.
I have a 1998 with the 5.7L. Any feedback?
http://www.performance-exhaust-heade...let/index.html
Any advice is welcome.
Old 11-01-2005, 01:05 PM
jveik jveik is offline
Re: Headers... tell me which set to buy.
dont buy a set of 700 dollar headers for your truck. Im assuming that it is all stock except for maybe the exhaust and intake, which basically is the same as stock. The headers will help, but dont pay a ton for them unless you have a matching cam and cylinder heads setup that needs that good of a header. the higher cost is i believe just for the finish, so if you are in a show maybe get the good ones, but some that have a crap paint job will do just as good as the expensive ones, maybe for 500 bucks less also.
Old 11-04-2005, 11:17 PM
sub006 sub006 is offline
I looked long and hard for headers to put on the 383 in my '90 Suburban. Settled on stainless steel Edelbrock shortys with the powdered titanium finish (Ti-Tec). About $350.
Indestructible finish unaffected by heat, water, chemicals. I find carb cleaner and a paper towel cleans 'em up fine (make sure they're COOL first!).
Like any headers, keeping them sealed is a challenge. Finally used Stage 8 locking bolts ($40)at the heads and double-nutted the collector bolts, except one which had too-tight clearance. This one I safety-wired.
Lovely harmonics through the 3" single exhaust and Gibson muffler at about 70 on the Interstate!
Old 09-05-2007, 12:04 PM
mudisfun82 mudisfun82 is offline
i got an '87 GMC 1500 with a '79 4-bolt 350 with around 300 hp its bored .030" with hyper pistons true roller timing crane 465 lift cam with matching lifters and springs 194cc heads with manley performance valves eldelbrock intake and a holly 650cfm carb... i will be using the truck for mud bogs and also as a daily driver...i need a good set of headers that will be usefull for both on and off road that will work with my engine mods without spending 600 bucks or more... any suggestion will be helpfull...thanks
Old 09-05-2007, 10:42 PM
mr_mushroom's Avatar
mr_mushroom mr_mushroom is offline
Send a message via AIM to mr_mushroom
i agree with sub.
those stainless edelbrock shorty's with ti-tech are the shit, and won't break your parts budget.
the other good thing is that they are in fact short. now you don't have as much to worry about with clearance.
all your are belong to us.
Old 09-09-2007, 01:17 PM
Follow-up sealing info. As mentioned before, Stage 8 locking bolts do the job permanently where the header flange meets the head.
But double-nutting and even spo- welding could not keep the collector gaskets tight! They'd always vibrate loose.
Dennis the exhaust tech at Edelbrock sent me the solution. They have collector bolt and nut sets with little spurs on the threads that dig in and really hold!
Happiness is headers that don't leak.
Old 09-17-2007, 09:10 PM
acewelderman's Avatar
acewelderman acewelderman is offline
Ive had great luck w summit racing headers! Low price !just bought the middle of the road painted ones & put good high heat paint on them before installing!
JUST WELD IT !!
