Old 10-31-2005, 11:07 PM
Bodaggit Bodaggit is offline
Send a message via ICQ to Bodaggit
Unhappy Just more problems.
I'm at my breaking point with this thing. I've had it just a little over a year, and already had more problems out of it than all my other vehicles combined.
I got my fuel pump, and everything worked good until tonight.
If I am driving were I can give it steady throttle, it runs like pure crap. Jerks and jumps and won't hardly run at all. Now, if I am going uphill and have to give it some throttle, it never misses a beat. When taking off it does good until the shift light comes on, then it starts stuttering and missing like crazy. When idling it idles smooth as a brand new one.
What in the world could be causing my troubles this time?
Old 11-01-2005, 08:09 AM
Re: Just more problems.
No takers on this one?
It couldn't be much of a problem, I was thinking maybe the fuel pressure regulator may have went out under the pressure of the new pump. It may explain why it runs better uphill where more gas may be needed.
Maybe the computer is going bad.
I think I just got a lemon.
In a year I've replaced the fuel pump twice, a wheel bearing, and had 4-wheel drive problems, and now something new has popped up and I just don't imagine it will stop there.
Old 11-01-2005, 10:21 AM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
What year Blazer? Miles?
1971 Chevy Monte Carlo ah.. the power of a V8
1993 Chevy Blazer: 97k miles, Flowmaster Exhaust, K&N Filter Charged
Old 11-01-2005, 12:00 PM
2001, 5 Speed, Apx. 90,000 Miles.
Old 11-01-2005, 12:04 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Originally Posted by Bodaggit
If I am driving were I can give it steady throttle, it runs like pure crap. Jerks and jumps and won't hardly run at all. Now, if I am going uphill and have to give it some throttle, it never misses a beat. What in the world could be causing my troubles this time?
I had this problem in my wife's Pontiac. The EGR valve was plugged.
Bucked like a wild horse at steady speeds with low loads (levelroad),Idle and acceleration were fine.
Search this forum for EGR Valve, you'll find tips on how to clean or replace it.
Old 11-01-2005, 04:07 PM
Thanks for the reply, at least now I have a place to start.
Old 11-01-2005, 10:58 PM
Hmmm..... How about one of the distributor cap bolts had backed back out? I suppose lock tite doesn't always work as good as you think it would.
I had the hood up and the engine running listening for anything out of the ordinary. I hear a weird clicking coming from the area of the distributor cap. So I turn the engine off, and then check to see if it had worked loose, and had it ever. I'm suprised it would even run.
I don't know if that's what my problem is or not, but it could very well be it. Didn't get much chance to work on it this evening, had other plans I couldn't cancel on.
