Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-31-2005, 09:57 PM
trantz trantz is offline
programming the keyless remote and door pad
Can someone share the instructions on programming the keyless remote and the door pad on my 96 lincoln towncar? Thanks, Tim
Old 11-01-2005, 02:07 AM
Towncar's Avatar
Towncar Towncar is offline
Re: programming the keyless remote and door pad
Hey Tim,
You need to know a few things about the system first.
  • The Permanent Code is printed on a sticker, affixed to the right-side trunk support arm.
  • You have the ability to enter up to three Personal Codes IF your system has the MEM 123 buttons on the Drivers Door Panel. If not, you can enter up to one Personal Code. Note: This point is under debate in several places. It seems model dependant.
  • The Memory 123 functions recall up to three Mirror and Driver Seat positions. Not all Town Cars have this Memory feature.
  • Key FOBS (remotes) are available in several types and functions. One is the MEM1, MEM2 designation on the back side of the remote, some have a small switch to shut off the function. The MEM1 opens the car and moves the Drivers Seat and Side mirrors to a preset position. MEM2 is obvious at this point. There are also FOBS with no MEM Recall designation, they just open the car and trunk without accessing the memory function.
  • Programming your Personal Code(s), and Remotes should be done all at the same time. If you have four remotes (the max), have all four with you when you do the programming.
  • Seat/Mirror memory(s) need to be Set prior to Assigning them to Personal Code(s) and Remote(s).
With all that said, it's really fairly simple. Here's a general Lincoln programming process:
http://www.lincolnsonline.com/tech/00013.html
You can also SEARCH this Town Car forum for Remote Programming or Keyless Programming and get plenty of hits.
-Steven
1996 Town Car, Cartier
Old 11-02-2005, 11:28 AM
sunny16888 sunny16888 is offline
look in ur manual it tells u how, i had a 96 towncar and did it many times but i think is that u need ur keyless entry code to activate ur remotes to work with it.
Old 11-02-2005, 07:38 PM
Re: Re: programming the keyless remote and door pad
Thank you very much for your help! I will let you know how it went.
Best regards,
Tim
Originally Posted by Towncar
Hey Tim,
http://www.lincolnsonline.com/article13.html
Old 11-02-2005, 07:40 PM
Best regards,
Tim
Old 11-02-2005, 08:48 PM
Your right, you need the factory code, located on the trunk hinge, 5 digits, and then I followed the instructions from the manual. Thanks a heap!!!
Tim
Old 11-02-2005, 08:51 PM
You need the factory code, located on the trunk hinge, 5 digits, and then I followed the instructions from the manual. Thanks a heap!!! The link you sent will help me program the rest of the car! All my ebay remotes work and I'm a happy camper. THANK YOU!
Tim
Hey Tim,
