Old 10-31-2005, 09:48 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
How to replace a starter...
Wow, this was a pain in the ass. I might as well do a somewhat detailed write up on it. Took me about 4 hours due to lift problems and me being retarded.
Well first thing is first, if you get a rebuilt starter, test it. Connect a battery and jump the positive cable to the solenoid using a wire or something to make sure it works.
Next thing, take off the drivers side front wheel and proceed to disconnect the tie rod, ball joints and rest of the suspension. The ball joints are 22 mm and I forgot the others. Youll also need to take off the axle nut, which is about 1 1/2 or 32mm, somewhere around there, I used 1 1/2 and it worked fine.
Assuming you have access to a lift( to make things easier), take a couple of flat head screw drivers and pry the part where the axle goes into the transmission, it should pop right out easy. It has a slip ring on it so putting it back in, you just have to pop it in.
Lower the car back down and take out the battery, upper intercooler pipe, and the 2 starter bolts which are 14mm each. You can do this first if you want, makes sense to, I didnt(retarded me).
Next youll have to fiddle with the starter to get it out, make sure to disconnect the wires going to it. Plug in the wires to the new one, have a friend hold it up while u put the screws in. Tighten it back up and prest-o change-o, you have a new starter.
This is also a good time to change your tranny fluid since a good amount leaked out. 75w90 gear lube works great
Enjoy all
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 10-31-2005, 09:50 PM
Re: How to replace a starter...
Forgot to add, if anyone ever gets a metal scraping noise when you start your car, the bearings are going bad and it would be wise to replace. But it wont hurt the car just for the fact its bearings, you wont rip teeth off your flywheel or anything of the sort
95 Eclipse GS-T
Currently:
Soon lol
Old 10-31-2005, 10:01 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Sounds like fun. I just dropped my car off at the dealership to have the starter replaced...for the 3rd time in 2 years. As long as they keep going bad within 12 months/12,000 miles, I'll be set.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 10-31-2005, 10:06 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
why did you need to pull the suspension apart? never looked at a 2g too close but on a 1g its just 2 bolts that go in from the back of the starter. pull the battery and uicp then unbolt the starter and slip it out.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-01-2005, 08:02 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I replaced a starter on my buddies 95 GST. I didn't have to remove any of the suspension. Weird???
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 11-01-2005, 08:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
The only thing I remove is the UICP. And battery if its still in the engine bay. It's been a long time since I've had to do it on a mostly stock setup though, so the cruise control and other BS may make it a pain in the ass.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-01-2005, 12:15 PM
I could barely reach it from removing the UICP, it was easier to get it from underneath neways, there werent any coolant hoses in the way.
95 Eclipse GS-T
Currently:
Soon lol
Old 11-01-2005, 08:02 PM
ned032002's Avatar
ned032002 ned032002 is offline
Yeah I can't see a reason why you had to remove ANY of the suspension either?
Old 11-01-2005, 08:48 PM
I didnt remove it, just un hooked it so i could pull the axle out about a foot or so
95 Eclipse GS-T
Currently:
Soon lol
