Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 10-31-2005, 09:15 PM
pejays pejays is offline
Send a message via Yahoo to pejays
Unhappy 84 celica will not start
I have an 84 celica that was sitting up for nine years with gas still in the tank. I put an aftermarket external msd fuel pump on the car, fixed all leaks in the fuel system. which is letting me know gas is getting up to the fuel rail for the injectors, but i am not getting anything on the sparkplugs. is there something that should have been done to override a sensor or something to turn on the injectors? I am completely at a loss for this one.
[email protected]
Old 10-31-2005, 10:19 PM
jwaj2002 jwaj2002 is offline
Re: 84 celica will not start
your filter is probably bad, if not your injectors are
Old 11-01-2005, 07:55 AM
Re: Re: 84 celica will not start
new filter. is there a way to check the injectors.
Old 11-01-2005, 10:01 AM
CelicaGirl CelicaGirl is offline
Send a message via AIM to CelicaGirl
It could be something as simple as a fuse. Check you're ignition fuse because that's what happened to me before. Like....it didn't seem like the fuel was going anywhere so I checked all my fuses.
Old 11-01-2005, 02:33 PM
yeah that is next on the list replacing the relays and checking fuses.
Old 11-01-2005, 04:02 PM
calicelica calicelica is offline
It could also be your alternator. Happened to my roomates 89 prelude once.
Old 11-01-2005, 08:05 PM
you will have to pull the injector rail, if they look burnt, get out the credit card or hit the junk yard
Old 11-06-2005, 09:29 AM
russiankid russiankid is offline
Send a message via AIM to russiankid
ok,first thing is first, gas has a tendency to bcome unflamable after a certain amount of time, and nine years?change the gas, drain it, poor in STP fuel injector cleaner, poor in a full tank of fresh gas, and it should start, it could be that the gas is so old it doesnt burn
Old 11-07-2005, 10:34 PM
if you didn't drain the tank you'll have to replace everything all over again, or atleast the filter, when you drain it I would suggest blowing out all of your fuel lines to the fuel filter
Old 11-11-2005, 01:21 PM
tank was drained, new filter, fuel getting to the injector rail, nothing pass the rail though. I am not getting any spray what so ever on the plugs.
