Old 10-31-2005, 08:13 PM
jck7282004 jck7282004 is offline
Question 91 cavalier ignition
On my 91 cavalier when i put the key in i can start it but the problem is when i let go of the key it springs back and shuts the car off. I don't know if it is my ignition switch or my ignition lock cylinder. The key is also stuck in the ignition but when I unscrew the ignition switch from the ignition cylinder the key is able to click back the right position to be removed. Pretty sure it is the ignition switch just need a second opinion.
Old 11-01-2005, 12:53 AM
Chevy454man Chevy454man is offline
Re: 91 cavalier ignition
your right on the money-changed lots of em! relatively cheap too! go figure!
Old 11-01-2005, 01:03 AM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
yeah just rent the wheel puller from autozone and be careful of the turn signal switch
Old 11-01-2005, 07:26 PM
12field 12field is offline
I had the same problem but for the year 1991 I didn't spend the money which was over $135. Instead used a spring on a chain and hook it up to the dash. If you know where to buy cheap, let me know. Thanks!!
Old 11-15-2005, 10:20 AM
devecme devecme is offline
Cool Re: 91 cavalier ignition
How did you get to and remove the ignition switch?
Please advise.
Thanks.
Old 11-16-2005, 10:40 PM
Re: Re: 91 cavalier ignition
Please advise.
Thanks.
You need to pull the steering wheel. Autozone gives you the puller to use for a small deposit. I think all the instructions are also on their webpage.
