Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-31-2005, 07:10 PM
lharper lharper is offline
Unhappy battery wont hold charge
My daughter has a 97 contour and the battery light stays on dimming brighter and lower with acceleration. We replaced the battery however they crossed the cables when installing then changed back after realizing it. She had it tested on engine analyzer and the mechanic said bad alternator. We replaced alternator and it drove for two days and continues to not hold charge. The battery cables were checked and replaced also. This has been going on a month and driving us crazy to figure out. If a dealership puts it on engine analyzer and can't figure it out then hoping maybe someone else has had same problem and can advise! Thanks!
Old 10-31-2005, 08:49 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
i bet the alternator relay is blown. Usually when the alternator goes the relay goes with it. Mine had the same problem after i replaced the alternator, and turned out to be the relay.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-03-2005, 08:54 PM
LC-x LC-x is offline
Re: battery wont hold charge
If i'm understanding your post correctly ... the battery light seems to be now working correctly .
If the charging system checks out ok and the battery passes a load test you might want to check for a parasitic draw.In other word a component in the vehicle is draining the battery when the vehicle is not running.
To check for this remove the negative cable on the battery and use a circuit tester (test light) between the removed negative cable and the Negative terminal on the battery. If you see a bright light (it may gradually fade) you have excessive draw that would drain your battery over a period of time. A faint glow which fades is normal on most vehicles , good luck
Old 11-08-2005, 08:06 PM
Thumbs up It is FIXED HOORAY
Well my Daughter took it back to Ford Dealer and they spent the whole day testing all the wires and they told her just when they were about to give up on it...........they found a fuse on the engine that had blown. The fuse was only 6.00 but it cost her 110.00. My daughter was so happy she paid her bill with a SMILE ON HER FACE and COULD NOT THANK THEM ENOUGH! HOORAY!
Old 11-09-2005, 06:08 AM
Re: It is FIXED HOORAY
was it the alternator relay like i suggested earlier?
"The CEG Nazi"
www.contour.org
Old 08-31-2006, 10:18 AM
meintool meintool is offline
where is the alternator relay?
Old 08-31-2006, 11:56 AM
if its the V6 its behind the rear valve cover on the wiring harness. Pop off the cover and you should be able to see it.
"The CEG Nazi"
www.contour.org
Old 09-11-2006, 02:32 PM
Super Wally Super Wally is offline
Does anyone know where the fusible link is located on the 2.0 Contour?
Thanks
Old 09-18-2006, 09:38 PM
lestro lestro is offline
Thanks
Don't know for sure if it's what you're wanting, but I believe there's a mega fuse on the intake manifold, between the alternator and battery
Old 09-19-2006, 08:42 AM
mikshad mikshad is offline
I have a 1996 Contour that won't charge. I believe it is the mega fuse. But I don't know what it looks like, or where it is located. If you find out please let me know.
Old 09-21-2006, 07:40 PM
carlos80 carlos80 is offline
there's no such thing as an alternator relay, at least not on Ford products
Old 09-22-2006, 09:46 AM
There is a 175 amp mega fuse located on the engine.
If you remove the plastic air cover from the intake and look down behind the center of the intake there is a rectangle box about 1 inch by 3 inch. The cover snaps off and located inside is the fuse. Remove the two nuts to take the fuse out. The problem I was having was the battery light was glowing dim to bright depending on engine speed and the battery was not charging.
I replaced the fuse and everything seems to be working fine now. It is a lot cheaper than a new battery or alternator. The car was a 1997 Contour with a 2.0 zetec engine.
