Old 10-31-2005, 04:51 PM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
30 Minutes to Install. Now need help!
Well I finally got it! Took me 30 minutes to install by myself.
Now I need help picking out some foglights to go with it so all suggestions would be appreciated. If you already have this set up with fogs, post a pic please so I can see how it looks.
Also, is it best to wire the fogs to the headlamps or actually use the toggle kit that comes in the wiring kits for them?
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
Old 10-31-2005, 08:22 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I would say use the toggle switch because sometimes driving with the fogs on and it is not raining or foggy or snowing and it can be considered illegal and you can be ticketed. I would use PIAA or maybe HELLA. Both seam to be really bright and have a great spectrum of light.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 10-31-2005, 08:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 30 Minutes to Install. Now need help!
Take a look at rlith's setup:
http://www.pghconsulting.net/teal/exterior.htm
As far as whether to use the switch or connect to the headlights...... I would do both:
Connect the power for the toggle switch to the low beam headlight wire. Then connect the toggle switch to a relay, that will power the lights.
Old 10-31-2005, 08:48 PM
blazee's Avatar
Problem?
I'd wire it like this:
