Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-31-2005, 03:30 PM
Airdale Mech.950's Avatar
Airdale Mech.950 Airdale Mech.950 is offline
Why NA??
I wanted to go NA on a B16B that I just purchased with some ITB's. I want a real screamer out of my del sol. I realize the amount of tuning you have to do with it. With my laptop and a plug and play program my car club made seems it might work.They use it on there own cars as well without problems. i ve been looking around and I keep hearing about how expensive it is to go NA and all this. is this just when you get over the 250hp mark or all together. what engine accessories do yall appove of getting to maximize my horsepower.
RTC Great Lakes
NATTC Pensacola
CVN-68 U.S.S. Nimitz San Diego
93 Del Sol D16Z6 Greddy 4-2-1 Greddy Evo2,
AEM cold air
MSD Ignition wires
15' GSR rims
http://www.myspace.com/ghostryders
Old 10-31-2005, 03:59 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Why NA??
you want 250 and have a b16b its doable.
Best thing i can say is up your displacement or be ready to get wild with head work and comp.
getting power N/A or F/I costs welcome to hondas =/
I would jump into the all motor area on honda tech many 250WHP cars and above using B motors
Old 10-31-2005, 04:50 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Bore. Up 12.0:1. Tune. Go.
Old 10-31-2005, 05:26 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Why NA??
I agree....overbore, up the compression, build the head, cam it, intake, header, good exhaust, tune that baby and go to town!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-31-2005, 07:18 PM
i think my greddy evo 2 will do with the exaust and my cold air from AEM I wanted to get can shafts from the B18 type R is the head work the only expensive thing about it. minus the tuning. Any good company that do good head jobs......speakin of head jobs im out...
RTC Great Lakes
NATTC Pensacola
AEM cold air
MSD Ignition wires
15' GSR rims
Old 10-31-2005, 08:44 PM
Ace$nyper's Avatar
Banned
Re: Why NA??
Wait you have ITBS and your buying a AEM intake because?
Your cams from the b16b are as mean as honda makes them swapping in b18c5 cams would lose you power.
for 250whp you'll be making life so much easier with stroking or boring your motor its really REALLY hard to get it out of a 1.6L if you dont want to do all that you can change for a frankenstien setup lsvtec like I have granted mines alot more for long life and staying to a rule book.
you'll need to start getting little wild with 250HP setup but you can keep her on pump gas.
i would search on the honda tech all motor area for 250 WHP all motor cars thats what i did for my setup and she runs ilke a dream.
anything else feel free to ask
Old 10-31-2005, 09:02 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Why NA??
block sleeved to 86mm, 12:1 compression. combustion chamber shaped to match the bore, and the biggest cams you can get before you run into interference problems, itbs, mad port work, one of those equal length headers. it might be a good idea to have the block girlded however you spell it, have the bottom end balanced for the high revs
Team Lonely Drivers
Old 11-01-2005, 12:47 AM
Kven's Avatar
Kven Kven is offline
Re: Re: Why NA??
250whp(street) is doable....with atleast 1.8L. Omniman was able to hit 200whp(barely though) on a b16a, with crzy headwork, rocket cams, (bottom end was stock I believe) and hondata.
The bottom part prep should be easy; just stroke it with ITR/GSR crankshaft and rods, and you have 1.8l with 12:1 compression(assuming youre still using the b16b pistons and stock headgasket). Some of the guys on H-T that are over 250whp are 2l also; so if you're going to get aftermarket pistons, go for 84mm ones and get the block resleeved.
The hardest/time-consuming part is the headwork and ignition/fuel tuning. Also, run no accessory except for the alternator.
The "cheater" way would be going with a 2.4l K-series hybrid (theyre around ~220whp with stock K20A2 or K20A head, k24 shortblock, and tune).
*Theres an article on IB that says not to match the combustion chamber to the bore.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-01-2005, 10:45 AM
so by the sound of it and all the info being thrown at me it seems much easier to go the b18c route if i want all motor striving for the all motor route I wanna get to the 250 platform but dont want to push my engine to the envelope doing it I want room for more horspower in the future. I think the easy way to go would be LS VTEC and slep a turbo on but how many mo fo's have that specially out in Cali Shout Out to North Island!!!!
I think the onnly reason I wanted to go B16B is because the swap woould be much easier the the B18 but now its looking like the extra time might be worth it. And by Cams I mean Camshafts not the gears if there was a mix upIve heard putting bigger camshafts helps opening the valves up more exp. during the vtec stage
I was thinking a K20a2 swap but I dont think I could do that on my own I think i would have to have a shop do that one.
RTC Great Lakes
NATTC Pensacola
AEM cold air
MSD Ignition wires
15' GSR rims
Old 11-01-2005, 05:19 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: Why NA??
what about a cylinder brace or solid sleeving (or whatever its called)
this pic of of a K20, maybe it cant be done with a B-series engine.
Seatbelts Saved My Life
Old 11-01-2005, 06:31 PM
Re: Why NA??
your talking about sleeving the motor ?
why cant it be done with a b series ? sleeving is done more on b series and d series than on k series
Team Lonely Drivers
Old 11-01-2005, 07:01 PM
Re: Why NA??
no, i meant the solid sleeving, maybe you cant put in a solid one like in the pic, i dont know. because i've never tried solid-sleeving a B-series block, or any block for that matter.
im not saying you cant sleeve it at all, im saying maybe you can use a solid sleeve, like in that pic.
Old 11-01-2005, 07:13 PM
Re: Why NA??
you can get your b series closed deck sleeves like that. i bet that pic is of a aebs sleeved block ?
Team Lonely Drivers
Old 11-01-2005, 07:25 PM
Kven's Avatar
Re: Re: Why NA??
or bensons.
1988 Honda CRX DX
Old 11-01-2005, 07:39 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
AEBS, Darton, Golden Eagle and Benson Performance Machining all re-sleeve blocks.
AEBS
http://www.aebsracing.com/products.pl?product=tsleeves
AEBS 8270 Miramar Rd
San Diego, CA 92126
858-693-3200
858-693-3449 FAX
Darton
http://www.darton-international.com/main_fr.htm
2380 Camino Vida Roble
Suite J & K
Carlsbad, CA 92009
800-713-2786
760-603-9895
760-603-9629 Fax
Golden Eagle Manufacturing
http://www.goldeneaglemfg.com/sleeving.html
414 Borrego Court
San Dimas, CA
909-592-4311
909-599-4692 FAX
[email protected]
This link will link you to their block dealers too if you don't want to go direct.
http://www.goldeneaglemfg.com/contact.html
Benson's Performance Machine
Dept. THP
2909 S. Kilson Ave.
Santa Ana, CA 92707
(714) 241-1284
Also, I didn't read it yet, but I found this article online and thought it might be interesting.
http://www.turbomagazine.com/tech/0112tur_stroker/
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
