Old 10-31-2005, 01:40 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
limits of a 2 bolt
how much power would you say a 2 bolt roller block could handle? I should be picking up a 350 block from 92 z this weekend. Curious as to how potent i could make this thing without trying to convert it to a 4 bolt. Or will i be limited by the stock crank first? Anyways $250 for the bare block bored .40 over. New main bearing, cam bearings, and freeze plugs. Polished stock crank. It is painted black. All i gotta do is have the deck plained or at least cleaned up and then start sticking stuff in there. It will be a nice little project. Then i just won a bid on ebay for one of those converted lt1 intake manifolds. Got for 127.50 and 20 to ship. I think it might need a little more modification but it will do. It also came with the fuel rails.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 10-31-2005, 01:47 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: limits of a 2 bolt
Depends how much money you put in. I've seen a 97hp honda engine crank out 1400hp cause they turbo'd and nitroused the hell out of a really built up engine,, it took tons of money (50k probably)
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 10-31-2005, 03:59 PM
Im not asking what the max power a small block can make is. 2 bolt mains on a regular sbc can only support so much power. 4 bolt mains make it stronger. I think i could get 400-425hp without worrying about the mains. Although i know a guy whos got a 383 lt1 who has got to be putting out over 450hp and it has 2 bolt mains. But it is an lt1 block and i dont know if the alloys are different or something. Of course hes got forged internals. So maybe if i get a forged crank ill be ok.
Old 10-31-2005, 06:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Reality check: A factory 4-bolt is actually slightly weaker than a well-prepped 2-bolt block under certain situations. If you're in need of a 4-bolt block for high-performance (such as nitrous, forced induction etc), then start with a strong 2-bolt block and have your machine shop fit aftermarket splayed-outer-bolt 4-bolt caps on it. The outer bolts that splay outward use the strength of the side of the block and oil pan rails, while the factory 4-bolt setup removes critical material from the main bearing web itself.
Old 10-31-2005, 06:40 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
A 2 bolt main is NOT stronger than a 4 bolt main but a 2 bolt splayed to a 4 bolt main is stronger than a factory 4 bolt main. However unless your making power in the 4 digit area. a 2 bolt should hold up just fine unless your getting some pretty heavy knock.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-01-2005, 01:16 AM
excellent. And since im not aiming at going anywhere near the 4 digit range(though not an entirely bad idea) I should be all good. But 4 digits seems like a very high number for a stock 2 bolt to hold. So with a factory block my limitation is the stock cast crank. What are some recomended modifications that i can do to the block to make it better. By better i mean more durable. Like sleeves or something.
Old 11-01-2005, 10:00 AM
silicon212's Avatar
Confoundingly Lucid
NASCAR Nextel Cup engines produce almost 800 HP from a factory block with no strengthening modifications - food for thought.
Old 11-01-2005, 10:27 AM
factory 4 bolt? or 2 bolt? Also it depends on what year the blocks were manufactured doesnt it. For emissions purposes they lightened the blocks in later years thus making them thinner.
