Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 10-31-2005, 12:50 PM
fordin K fordin K is offline
misfire codes.
iI have here a '00 passat 1.8t a/t . with codes p300-p304 and p1128
and the p300, 301, 304 all have "B" at the end. engne seems to work fine. also there is a symbol iluminated that looks like a exclamation mark in a triangle inside a arrow formed in a circle. I don't have the owners manual so I don't know what the hell it is. seems maybe a maintenance reminder or some thing. any help would be appreciated. veedubmechanic any suggestions ?? tnks
Old 10-31-2005, 12:53 PM
Re: misfire codes.
let me just add that after jumping in the car now and hammering the throttle it bogged at about 2500 rpm and hit rev liimiter at about 3500rpm then let it run alittle bit then worked ok.
Old 11-27-2005, 11:03 PM
bahnfire bahnfire is offline
Re: Re: misfire codes.
Not sure about your misfire codes, in the VR6 they usually mean that the coil pack is cracked and letting moisture in. The P1128 error code could be a bad mass airflow meter, a bad 02 sensor, a bad catalytic converter, a vacumm leak somewhere, or a clogged air screen in the air box. In my case, it was a clogged air screen at 80k.
Old 01-05-2006, 08:13 AM
JDUB377 JDUB377 is offline
Re: misfire codes.
Isn't that symbol the traction control? Try turning the traction control on and see if the symbol turns off.
Old 01-27-2006, 04:12 PM
GSPFAN GSPFAN is offline
Re: misfire codes.
yeah it is traction control. Is it by chance slippery where you are?
