Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 10-31-2005, 07:57 AM
marragtop marragtop is offline
Help with headlight adjustment 94 GTC Convertible
I have a 94 Lebaron GTC convertible and for some reason, I can't get the headlights adjusted. I have taken the lens and adjustment assembly off of the car, and it looks like the adjustment mechanisms are working properly. However, when I put everything back in the car, and turn the torx screws, the beam just does not move. This is true in the up/down and side to side adjustments. It doesn't matter how far I turn the screws in either direction, the beam just doesn't move. This is true for both headlights. Is this a known problem, or am I doing something wrong? Any/all replies are appreciated.
thanks
Old 10-31-2005, 10:19 AM
94LebConv3La604 94LebConv3La604 is offline
A lot of the time, headlight adjustments that old simply rust up out of lack of use....I mean how often do we fiddle with the trajectory of our headlights? Unfortunately, you probably need a new housing. Keep trying, though. Maybe some lithium grease or WD-40 on them will help.
Old 12-14-2005, 11:06 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
Re: Help with headlight adjustment 94 GTC Convertible
the threads that the screws go into might be stripped.
Justin
Old 11-06-2006, 04:49 PM
ricebike ricebike is offline
werd, my dad stripped the pass side headlight, but lenses are yellowed out & beam is diffused... sux to drive this thing @ night!
