Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-31-2005, 07:47 AM
BamaRodeo BamaRodeo is offline
water pump
Is there a way to test the water pump? Here lately I've noticed the hot smell of coolent after driving. None of the dummie lights have come on, and I see not leakage. However, I'm hitting the road this weekend and dont want to worry about it 'officially' going out in the middle of no where.
Any ideas, suggestions, etc?
Thanks
~BamaRodeo
'99 2.2L Rodeo
'06 Mini Cooper
w/ guitar in back
Old 10-31-2005, 08:20 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: water pump
normally you will see a little leaking, and will hear a bit of bearing noise.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 12-17-2006, 01:50 PM
pennfire51 pennfire51 is offline
Re: water pump
a bearing noise? Is that like a windup scren type of noice everytime you push on the accerlorator? cause my truck started doing that a couple days ago and i am wondering what it is. i have a 99 isuzu rodeo
thanks for the help
calvin
Old 12-17-2006, 02:13 PM
trooperbc's Avatar
trooperbc trooperbc is offline
Re: water pump
Originally Posted by pennfire51
a bearing noise? Is that like a windup scren type of noice everytime you push on the accerlorator? ...
calvin
could be, it also could be a slipping belt. usually the belt will first show up when it's cold and then get better as the air heats up either from the engine or the sun.
you can try to use a mechanic's stethoscope to help locate the source, or a piece of hose in your ear or a length of old broom handle or even a long screwdriver -- anything that will help isolate the sound and direct it to your ear
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 12-17-2006, 03:08 PM
Ramblin Fever Ramblin Fever is offline
Re: water pump
My waterpump failure didn't really give any warning - no leaking, no noise. Except 2 days before it went, I started hearing this bearing type noise, but it was also REAL cold so I didn't think too much about it; finally on the 3rd morning it started sounding like I threw a rod and was dumping antifreeze everywhere - at that point it was a given.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 12-17-2006, 06:38 PM
surferfletch surferfletch is offline
Re: water pump
Look around for leaks! Search to find the common spots.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 12-17-2006, 07:01 PM
Re: water pump
also today when i got home and waited a little bit there were a couple drops of antifreeze on the ground. does that help?
calvin
Old 12-17-2006, 08:12 PM
trooperbc's Avatar
Re: water pump
calvin
where were they? i mean what part of the engine was above the drips. crawl under and follow the green....
//bc
