Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 10-31-2005, 07:21 AM
sunbird94 sunbird94 is offline
Unhappy sunbird le 1994 2.0 problem with starting
my water pump went out,replaced it but person who did messed up crank sensor, replaced that but car still wont start..turns over but nothing. could it be the ecm???I f so where is this part located?
Old 11-02-2005, 10:42 PM
Madcat455 Madcat455 is offline
How did he mess up the crank sensor??? Only the wire runs anywhere near the water pump.. did he cut it, or damage the wire?? If so, when you replaced the sensor... did you remove the timing belt and cam/crank gears to run the wire behind the back cover like OEM??
It could be a number of things that's causing it not to start... First, I'd double check to make sure the timing belt was put back on correctly (with the cam and crank gears properly aligned)...
Have you checked for the reason it's not running?? does it have spark.. is it getting fuel...
Ironically... I recently had the wter pump on my 94 2.0 replaced as well... then two weeks later the CPS went bad...LOL.
