Old 05-25-2002, 12:33 AM
thewoahna's Avatar
thewoahna thewoahna is offline
Send a message via AIM to thewoahna
What Would You do?
OK, I am really mad... I got my new headers (DC Ceramic) for my 1990 Accord. I have a family friend who is a mechanic, and he helped me install them. After I got them on, I had a leak right where the 2 pieces come together (Two piece header), so I thought that my sealing rings were bad, so I got some new ones. Well, I had my friend help me once again take the headers off and put new gaskets on, this time using a high-temp silicone allong with the gasket rings. Well, I let the car run, and I put my hand beside the joint where the 2 pieces come together and could still feel a leak, this time I looked really close and realized that my new header has a small hole in the weld, and this is where my exhaust was leaking the whole time. Now here is the problem... I calld DC and they did not seem to want to help me much, but they did say that if I sent it in, that they would patch weld it for me. Now do I pay my family friend to put my stock back on, and replace the headers when they come back, also paying for shipping to DC Sports OR do I just pay my friend once to take them off, sand off a little of the Ceramic coating around the hole in the weld, and patch weld it myself and put it back on the same day? I am thinking to fix it myself, the hole is very small, would welding it myself fix it? Will it last? Should I just leave that small hole alone? If I leave it alone, will it just get bigger over time? I know this is a very long message, and I hope that You are all able to understand my problem. Thanks for your feedback!
Whenever at a loss of words, "Woah Na!" will suffice....
AOL IM: WoahNa316
Click here for some of my car pics/stats
Old 05-25-2002, 12:02 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
there is a product called JB Weld, use the high temp epoxy they use and seal the hole. if it is as small as you say it is, the patch from JB should work fine, and you wont even need to take them off to do it.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-25-2002, 02:29 PM
rendog24's Avatar
rendog24 rendog24 is offline
do u have 2 "headers". i dont think so, so therefore it is a HEADER. singular.
other then that i would bitch so much at dc and make them pay for eevything or the place that u got it from because it is defective. or if u really need it that bad then diy.
"Don't touch what you can't grab, End up with two backhands, Put anthrax on a tampax, and slap you 'til you can't stand" - Eminem
