Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-30-2005, 10:04 PM
abilyk abilyk is offline
separating 'U' joint from front axle assembly
Should the 'U' joint on the drive front part of the drive shaft separate easily from the front axle assembly or should I give it a little persuasion with a block of wood? I thought it would separate very easily. I have to drop the front axle assembly to get the CV shafts out for replacement. I had a bit of trouble with the mounting brackets at the end of the axle assembly and I think I'll need new mounting hardware since one bolt came out with half the rubber bushing still attached to it. I hope I can get these parts easily here in Toronto. I also broke my pitman arm puller trying to get the pitman arm off. That part is on really good so I had to work around it and managed to get the center link and tie rods off in one assembly without removing the pitman arm and the idler arm.
Anyway, I will continue work on Tuesday since I am taking the kids Trick or Treating tomorrow. Bye for now.
Alb
