Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-30-2005, 09:27 PM
apisraelson apisraelson is offline
1991 suburban is missing bellow 35mph
My 1991 suburban is missing bellow 35mph at higher speed it runs fine it has new cap, roter, plugs and wires,
dose anyone have any ideas what is going on.
thank's.
Old 10-31-2005, 12:52 AM
Ryan685 Ryan685 is offline
Re: 1991 suburban is missing bellow 35mph
Was it missing out before you replaced the cap,rotor & wires etc?
Take each spark plug out (again) one-at-a-time and look at them. You need to know what cylinder is not firing and why. There are many possibuilities. For instance, a bad injector on that one cylinder will cause it to not get fuel. Once the engine gets above a certain rpm you just don't feel the miss but it's still there. If one cylinder was low on compression, it would also miss out as you describe. A leak-down test would determine the condition of the engine. A leak-down test is different then a compression test. Leak-down testing will determine where the leaking compression is going. Valves, rings, head gasket etc. If you or someone can do a leak-down test on the suspected bad cylinder. That cylinder's piston is brought up too it's compression TDC (4-stroke, intake-compression-fire-exhaust) An air fitting is screwed into spark plug hole. The leak-down tool measures psi of air lost in percentages. I think 6% is bad for any engine but some people like to see double digits in loss before they start to spend money.
Old 10-31-2005, 11:13 AM
thank's for the help
It turned out to be a durty injector. It runs good now.
