Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-30-2005, 08:41 PM
cookie27 cookie27 is offline
83 prelude will not idle
I have an 83 prelude that will not idle.I have changed both fuel
filters,checked fuel pressure,rebuilt carborators.The idle solinoides
have power to them and seem to be working.I have also run a
compression check, changed plugs and added fresh fuel. The car
has set for aprox 4 years.Any ideas???????
Old 11-07-2005, 11:13 PM
filip9999 filip9999 is offline
Re: 83 prelude will not idle
check the idle a/f mix screw as well as the idle speed screw
Old 11-08-2005, 09:34 AM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
Yep, if it just dies down when you don't throttle it just take a screwdriver and adjust the Idle Air Control valve. It's under the carburator.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 11-09-2005, 09:01 PM
can I get some more info on the idle air control valve for the 83 honda prelude?. will the carbs have
to be removed so I can see and get to it??
thanks
Old 11-15-2005, 08:26 PM
ull have to take the air cleaner off most likley and it should be a screw near the butterfly valve
