Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-30-2005, 06:32 PM
bkend bkend is offline
95 maxima wont start when warm
I have a 95 max that recently had the alternator replaced. now stalls once warm & wont start when warm. starts & runs great when cold. mechanic plugged in & told me cylinder 2 missing. replaced plug & its coil & reset engine light. Still will not start when warm (wont take it far from home to see if it stalls when warm yet).
Old 10-31-2005, 12:35 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 95 maxima wont start when warm
6 cyl engine 'works' with 2. Thereby one missing cyl can never prevent engine from starting: dont look at single cylinder as a cause, but smtg that controls the whole group.
First check batt & charge voltage, 10$ multimeter is a must.
When the problem is 'ON', easy DIY tst is to diconnect MAF; should start. If it does, works in 'safe mode' with 2.2k rpm limit: go buy used MAF from junkyard and swap.
'No other' single source may kill engine like that, except some connector failure - or ECU. There may well be two simultaneous problems, which really culd make troubleshooting difficult. Connectors should be cleaned, see whattodo: http://www.cardomain.com/ride/748507/14
