Old 10-30-2005, 06:30 PM
Killa's Avatar
Killa Killa is offline
head gasket ??
My ex girl have a 1990 laser ( auto ), with 1991 eclipse ( 5 speed ) engine. Her car is some time over heat , and if you let the car warm up , step on the gas, big smoke come out, and if you let go the gas, the car have no smoke ( but some time it will smoke when the car idle ). She lost alot of coolent , like when it empty. pop the cap ( the one of top of thermerstat ),refill, then let it idle for a while, check the cap , no more collent . Can any one know what the problem here ?. thanks
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 10-30-2005, 06:41 PM
Talont28 Talont28 is offline
Send a message via AIM to Talont28 Send a message via MSN to Talont28 Send a message via Yahoo to Talont28
Re: head gasket ??
well one way to check if the head gasket is blown is check the oil if its orangy colored then yes you have a blow head gasket...oil is mixing w/ anti freeze...kinda sounds like a seal may be bad in your turbo...when i had a seal go bad it was only when i let off the gas i got smoke and once in a while at idle...check the band around the exhuast side of the turbo and look for oil...then check shaft play
Hope it helps
Jesse
Its a Dsm thing...
<img src="http://www.dsmtuners.com/gallery/data/500/44010Pcdv0154-thumb.jpg">
Old 10-30-2005, 06:50 PM
Killa's Avatar
she dont ride a turbo car ( either do I )
GM FOR LIFE !!
95 camaro lt1
Old 10-30-2005, 09:10 PM
Killa's Avatar
So it a head gasket problem ?.
GM FOR LIFE !!
95 camaro lt1
Old 10-30-2005, 09:30 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: head gasket ??
Like talont28 said... check the oil, if it looks kinda creamy somewhat like a frothy miracle whip- that means your coolant and oil is mixing together.
Noone here can really tell you if it is a headgasket problem or not unless you look into the things we ask you about....
Just because you put coolant in and rechecked it doesn't necessarily mean that it is leaking... it might just be low still....try to add more.
Did you check the turbo for leaking? shaft play? If the seals inside the turbo are leaking internally than you will be sending either oil and/or coolant out the exhaust which would explain the smoke.
Check all these things and then let us know what you found..... until then we can only speculate......
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
