Old 10-30-2005, 04:53 PM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
No accesories
with the key turned to accesories ...nothing works ( thats supposed to work on accesories).. all the fuse labels are wore off...but i have a picture of it in the manual and i dont see any fuses labeled acc. ....but in the radio schematic in the manual it mentions one....( it says it is 20 amp)....so the question is..IS there really a fuse for the acc.? What else could be the problem? ..and where would i look for that problem?
Thanks john
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 10-30-2005, 08:49 PM
The deal is i was wiring in a new radio...well everything worked fine until i turned on the accesories.......i dont have any..( i think its been this way since i got the car.....it just never bothered me)..im 100% sure i got the radio wires correct...but its more than the radio..nothing works
well i overlooked the fuse....i found the fuse...anyway i tested it and its good..i tested the power there ..and i got power at all times (acc/on/run/start/) maybe the fuse is in between the battery and the switch??.....but what am i looking for ? bad ignition switch??
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 10-30-2005, 09:49 PM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
Re: No accesories
mine didnt work on acc sometimes, but are you doing accessor when you trun the key backwords or just a little foreward? cause if you push the key and go backwords all the way it might work, mine did like that. good luck
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 10-31-2005, 10:02 AM
im turning the key backwards.....
this might be unrelated, but yesterday when i was working on it..i turned my instrument lights on ...and they came on then quit...i assumed a fuse........but the fuse is good there ( although there was a 25A fuse in there when it is supposed to be a 5A)....there is no electricity at that fuse anyway.....
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 10-31-2005, 11:37 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: No accesories
For the radio, you should have a hot at all time (orange) for the radio memory. There should another wire, usually yellow which is the fuse panel feed, and only hot when the ignition is in acc. On that note, if you have nothing when in acc., then it's either the fuse or the switch.
Check the grounds for the dash out, I beleive they are right in the area on the radio and you broke one?
Old 10-31-2005, 05:57 PM
yes ornage goes battery ( hot at all times) and the yellow one is supposed to be hot in Run or acc..its hot in run.but not in accesory..like i said i checked the fuse ....its good....so is it the ignition switch?
700R4
Holley 650 Cfm
Hedman Y-pipe
NOS Decal
VTEC Decal
Old 11-01-2005, 08:38 AM
wrightz28's Avatar
Re: No accesories
Good chance on the switch problem then
