Old 10-30-2005, 04:01 PM
rc11982 rc11982 is offline
Angry 94 c1500 won't idle
Ok here is my story hope you can help.....
*side I am doing this job for a single mom with two young boys*
Truck starts...won't idle....dies
the truck starts only when i give it a little gas. if i don't give it gas it dies out in order to keep it running..i have to keep my foot on the gas.
have replaced the fuel filter....fuel pump...and now are out of ideas.
please help help help
Old 10-30-2005, 06:12 PM
maxwedge maxwedge is online now
A990 racer
Re: 94 c1500 won't idle
Are you getting fuel through both TBI injectors?, Take off the egr clean the pintle and seat, maybe carboned, lots of possibilities here, on site help may be your only avenue. pS, check for major vacuum leaks, cracked/disconnected large vacuum hoses, spray carb cleaner around the throttle body to manifold area, see if the engine changes response.
Old 12-25-2005, 11:00 AM
willgrimes1939 willgrimes1939 is offline
Unhappy Re: 94 c1500 won't idle
I have an 88 1500 c/k and I had the same problem and I was able fix it by replacing the idle air controle valve located on the TBI. It sounds like that is your problem.
Old 12-25-2005, 02:09 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Re: 94 c1500 won't idle
ya also try the tps censer.
