Old 10-30-2005, 03:38 PM
sblkcamaro70 sblkcamaro70 is offline
Question need torque
alright guys i kinda have a dilema here. i finally put in the 88 hf tranny in my 89 civic. every thing works great. but i figured this would happen. it dropped the rpms down too low in fifth gear and it is sucking way to much fuel just to maintain speed. i end up just running it in 4th gear. so my question is what should i do to lower my torque curve down to about 2000 rpm like the d15b6. i dont really want to have to put the d15b6 head on because then i will have to put different pistons in. i need some help guys thanx.
Old 10-30-2005, 04:11 PM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
Re: need torque
why did you put the HF tranny in? shouldve went with the Si tranny or somethin..
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-31-2005, 09:55 AM
well cause i am going for strictly gas mileage.
Old 10-31-2005, 01:17 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: need torque
Then buy an HF...
Old 10-31-2005, 01:59 PM
why would i want to buy an crx hf when i have a civic already and i have a hf parts car. my question i have is i make some threads here and there and no one ever answers them. they always throw in their little tid bits of b/s and i really dont care to hear them. why cant we get people to just answer the questions. it is just kind of annoying
Old 10-31-2005, 02:05 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: need torque
Underdrive pulleys may help... maybe a lightweight flywheel. A turbo would definitely add torque but that would kill mpg.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 10-31-2005, 02:34 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: need torque
if you want lower torque then increase your stroke or just raise the power band you have now.
try intake, header, exhaust. also if your going for gas mileage why do you need more torque, that shows that you want more power to go faster which mean more gas and that will just kill your gas mileage.
also the motor doesnt suck fuel, the injectors give it fuel, so if you think your running too rich look at your fpr or your injectors
Team Lonely Drivers
Old 10-31-2005, 02:48 PM
civic killer i know it doesn't make much sense that i need more torque. it isn't that i nessicarily need more torques i just need to get the power band down around 2000rpm. i cant really explain what it feels like for the motor to be pulling the hf tranny. the best i can explain it is i am pulling a trailer. the only way to for the motor to pull this transmission is to lower my torque curve. what i think i am going to have to do is use the d15b6 piston and head to lower the torque curve. i would also like to take a d16a6 crank and put it in the motor because if you look at the specs it has a longer stroke. next question i have is where can i pick up a d16a6? any one have one for cheap
Old 10-31-2005, 02:57 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Re: need torque
I have a D16A6 bottom end I just took out for my swap. Make me an offer.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 10-31-2005, 02:59 PM
you have the rods to go with it?
Old 10-31-2005, 03:01 PM
Re: need torque
It's the whole bottom end.....pistons, rods, piston rings, etc etc. It's all still together.
Old 10-31-2005, 03:02 PM
well i would only need the crank and rods, because i would use the pistons rings and whole top end from my current motor
Old 10-31-2005, 03:03 PM
shit what am i thinking i would need the pisons to o
Old 10-31-2005, 03:08 PM
i dont know what is it worth to you
Re: need torque
so you just want the crank, pistons, and rods? right?
