Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-30-2005, 02:05 PM
HontegraGSI HontegraGSI is offline
Messed up doing simple coolant change!!! got a question...
So i was changing my coolant and as i put the last drops in radiator, i just noticed that it wasnt 50/50 with added water i had to add water!!! well i was wondering what would happen if i didnt add water... my brother told me to just fill water in the reservoir and it will mix. will this fix my prob??
95 Integra GSR (4 sale)
89 CRX Si B16a (Sold)
98 Civic eK
Old 10-30-2005, 07:27 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Messed up doing simple coolant change!!! got a question...
it won't work as well as the 50/50 mixture, but it will work. I think the only time that it will matter is when it gets hot outside.....Ethylene Glycol helps in the cold because alcohol doesn't freeze, but it also doesn't dissipate heat as well as water.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-30-2005, 10:09 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
a 60/40 mixture is the max i would go to. why dont you just redrain and redo it?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-30-2005, 10:45 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
There's a point at which too much antifreeze hurts, and RAISES the freezing point, and 50/50 gives good coverage and is easy to guesstimate. But I warn against filling the bottle with water because it can and will freeze, and could potentially crack the bottle giving you problems. If the mix is really screwed up, drain it and do it again.
