Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 10-30-2005, 01:25 PM
dobermankid dobermankid is offline
Send a message via AIM to dobermankid Send a message via Yahoo to dobermankid
98 Mirage DE Fuel Filter
Does anyone know where the fuel filter is located?
And is it difficult to replace?
Old 11-06-2005, 07:41 PM
evoryda evoryda is offline
standing in front of the car it to the right mounted near the back, the easiest way to find it is to follow from your injectors fuel rail to the right down the fuel line, its black and has a banjo style bolt on the top. pretty simple to change, but do it while the motor is cold/fuel system is not under pressure. and put plenty of rags down to catch gas cuz it will leak out.
Old 07-05-2006, 03:46 PM
97MirageDC 97MirageDC is offline
Re: 98 Mirage DE Fuel Filter
the fuel filter is located under the rear seat, and it is not too hard to replace if you know what you are doing.
Old 07-06-2006, 11:17 AM
DFBonnett DFBonnett is offline
The filter for the '00 is also located as noted by evoryda. I believe the '98 is pretty much the same as the '00. You might also wish to spray some penetrating oil such as PB Blaster or Kroil on the fittings once a day for a couple of days before you try to remove the filter. Those fittings can be pretty bitchy to remove sometimes and the last thing you want to do is bugger up the fittings.
