Old 10-30-2005, 12:37 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
How to make cig lighter a switch for neons?
Right now I've got my neons grounded and ready to hook up to a power source. I'm going to hook them to my cig lighter and was hoping that I could use the lighter as a switch as well.
While doing random searches one day I found this posted by Eclipse RST:my boost is set to 15psi for daily driving but when i push the cigarette lighter it sets it to 23psi! http://www.automotiveforums.com/vbul...ght=pink+slips
Does anyone know if it's possible to do this to my neons as well. Hook them up somehow and when I press the lighter it turns my neons on.
Thanks
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 10-30-2005, 01:34 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Re: How to make cig lighter a switch for neons?
You would just have to make the lighter plug into a switch, I don't think you could have it function as a lighter as well. Just make something where when you push the lighter in it completes a circuit, you know, a switch.
I'm>everything
Old 10-31-2005, 02:23 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Re: How to make cig lighter a switch for neons?
I wish I had taken pictures of this.. but they have crimp ons for the lighter wires...... In the side panel drill a hole with a hole saw for your switch. Mount it there.. Connect the side going to the lights (positive) to one side of the switch. The other pole they have "splicing" crimps ons.
You slide it over the existing positive wire on the lighter. Place the swtich wire in the hole on the crimp and bite down on it with a pliers. It crimps into the existing lighter wire. They sell them at autozone or a home depo cheap. Great if you hate dealing with splicing.
If you want pictures I'll pull off my side panel tonight and take them. PM me.
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 11-01-2005, 12:39 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Just a suggestion... above your stereo where the center vent is... on my old car anyways there was an empty spot by the hazards switch/center vents that would be good for a toggle switch.... i've even seen a dual switch... push once for on and push again for off.... not sure the exact switch name but you get the drift....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 11-01-2005, 07:52 AM
Yeah I've got that area too. It would be a paint to run wires up there though. I just took apart my interior and then put it back together. Now I've got to run wires and I'm trying to keep everything intact if I can.
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 11-01-2005, 07:58 AM
nova1313's Avatar
those vent's pop out... so do the switches. If you take off the bezel around your dash guages then you can see on that side there is empty space there... Tie a washer to a wire and drop it down. It will pop out down below behind the cig lighter from there. I think you should be able to get it down that way. Otherwise the heater controls extend back far so you really have to go back around them. That should be the hardest part if you decide on there... Ever think of inunder the change box's lid. Like build a platform. Then you can flip up the change thing and hit the switch. You should even mount a pilot led there so you knew when it was on...
Just a thought if you don't use that slot.
Old 11-01-2005, 09:07 AM
LPFreak1283's Avatar
LPFreak1283 LPFreak1283 is offline
Send a message via AIM to LPFreak1283
Hey guys. I was wondering if you could let me know what the wires in the console run to. There are 3 sets of wires (2 lights, cigarette lighter). Mine were all just sliced by someone when they owned the car and I am trying to get the lighter hooked up...mayeb install indoor neons on the light wires?? Any help would be appreciated.
I used to drive a 90 Plymouth Acclaim
Now, I drive a 90 Eclipse GSX!
"God came down from the heavens and saw an Eclipse speed past him. He smiled and said "Look what I have created!"
Old 11-01-2005, 11:37 AM
Re: Re: Re: How to make cig lighter a switch for neons?
Yeah I though about that but don't want to lose my cupholder(2g) and my ashtray has my remote bass knob mounted in it. I think I'm gonna end up putting my switch on the lower side console panel. Then the switches are hidden, easy to get to, and short amount of wire will be used.
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
