Old 10-30-2005, 12:09 PM
asolinger asolinger is offline
Turning Over but not starting. Need help please...
92 Silverado V6. Was drivingdown the street and truck started to sputter badly then died. Was able to start truck but it died immediately. Checked the spark plug wire and noticed it had been sitting on the engine and burned through. Obviosly need to change them. Checked the coil and it is getting spark. Before buying all new stuff, I would like to know what I can start checking beyond the Spark Plug wires. The cap and rotor look good but I don't know much about the Coil unit inside the Distributor. Any help would be great. Thanks
Old 10-30-2005, 03:17 PM
maxwedge maxwedge is offline
A990 racer
Question Re: Turning Over but not starting. Need help please...
How long since the the cap, rotor, wires f/filter, and plugs were done, basic tune up stuff?
Old 10-30-2005, 03:48 PM
Been quite a while. Couple years I'm guessing. Just got some new wires, Cap/rotor, fuel and air filter. Gonna see if they fix it. Any other ideas would be helpful in case those do not turn out to be the issue. Thanks, Aaron
Old 10-30-2005, 03:50 PM
broughy84's Avatar
broughy84 broughy84 is offline
While you have it all apart (and by the way, I would change the cap and rotor anyway) I would go ahead and take the ignition module out and have autozone check it out. They will do it for free and it will tell you if it is faulty. If the coil has spark, I wouldn't worry about that. 9 times out of 10 it's the ignition module that goes out on these trucks anyway. If i remember right, it takes either a 5.5mm, 6mm, or 8mm socket and ratchet to get this off, I can't quite think of which one it is though. Then of course there are two plugs on it. Pretty easy to change.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 10-30-2005, 11:14 PM
Where is the ignition module? Is it inside the distributor? I know it sounds liek an ignorant questions, but if I don't know I don't know. Thanks
Old 10-31-2005, 06:33 PM
broughy84's Avatar
inside the distributor, under the rotor. When you get the cap off you will see it. it has 2 plug in connectors.
Matthew Brough
Old 10-31-2005, 11:26 PM
Thank you Matthew. I appreciate the help. Today I changed the wires, plugs, cap, and tested the Coil. The coil was getting spark but the plugs are not getting any spark through the new Cap, wires and plugs. I am changing the Ignitiona Module, btu don't know what else it could be. Puzzling for sure.
Old 11-01-2005, 11:12 AM
broughy84's Avatar
sounds like the ign. module.
Matthew Brough
Old 11-01-2005, 04:03 PM
Re: Re: Turning Over but not starting. Need help please...
Changed the ignition module, coil and still wont get juice to the plugs. I am very puzzled and frustrated
Old 11-03-2005, 09:23 AM
sherman69 sherman69 is offline
Re: Re: Re: Turning Over but not starting. Need help please...
[quote=asolinger]Changed the ignition module, coil and still wont get juice to the plugs. I am very puzzled and frustrated[/QUOTE
I hate to be a wise guy, but I keep wondering if you forgot to put the rotor back in? Or if the center spring under the coil got lost.
It contacts the center of the rotor.
Bob B
Old 11-04-2005, 06:55 AM
derekbitt derekbitt is offline
I have had an ignition module go bad on me before, the truck just died and would not restart. if you replace it you must use heat dissapating dielectric grease to mate to surface of module and distributor or it will burn out on you again. the ignition module is one of those things that goes bad on chevy engines,
D
Old 11-04-2005, 06:57 AM
also check your battery cable connections, clean and tighten!
