Old 10-30-2005, 11:19 AM
jamesmetairie jamesmetairie is offline
96 won,t start=
a friends 96 lumina won,t start . he says acts like it,s ignition switch. suspects it,s passive security system. any idea,s appreciated.
Old 10-30-2005, 11:32 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 96 won,t start=
Try giving the starter a whack with a light hammer while somebody holds the key all the way over to "start", sometimes on GM's the starter will hang in a dead spot, jarring it will get it turning again.
My '97 went through a period of that a month or so ago, I was prepared to put a new starter on, but then it didn't do it anymore after I cleaned up the terminals at the starter.
It'll probably wait for the coldest week in the winter to crap out...so I can lay on the ground and fix it...
If the starter is cranking, ignore the above. If your friend has a spare key, try it. Sometimes it will contact differently if the VATS system is what's keeping it from starting.
Otherwise, the usual suspects, IM, crank sensor, etc.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
