Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 10-30-2005, 11:12 AM
Fredrick_NP's Avatar
Fredrick_NP Fredrick_NP is offline
Start up is sounding harsh... (2000 2.2L)
It makes a somewhat loud clunk noise every time you start it. I mean... it never has problems starting, its just a very unpleasent sound that it didnt use to make.
Has anyone else had this problem and do you know how to fix it?
Old 10-30-2005, 03:46 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Start up is sounding harsh... (2000 2.2L)
I haven't experienced the problem but you could have a bad motor mount, transmission mount or an exhaust that is hitting when the engine turns over. Have these items checked out and you should find the problem.
Old 11-03-2005, 02:36 PM
matt09524 matt09524 is offline
Send a message via MSN to matt09524
Make sure you don't have anything loose inside the engine compartment as well. If it makes that noise every single time, you may need to just tighten something or put something back where it needs to go.
Old 02-23-2006, 07:51 PM
ripsterone ripsterone is offline
I just bought a 99 sunfire 2.2L with the same problem. It sounds like three consitance knocks and it maybe coming from the dash or firewall area. I will have to check the mounts and maybe the speedometer cable.
Old 02-28-2006, 07:18 PM
Well I got a little time to check it out today and the only thing I found was the mounts might be warn. I can place my hand on top of the motor and without much force move it back and forth. Can someone tell me if they can do the same so I will know for sure that they need to be replaced.
