Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 10-30-2005, 11:53 AM
jkayhome jkayhome is offline
2001 Aztek gear stuck in park
Just yesterday my gearshift won't come out of park. Found the bypass and can push that in each time to get it to move. Once it's out of park I have no problem. Does anyone know what this could be? I'm out of warranty so unless it's an electronic module that is still under warranty I can't afford to take it to the dealer. I've heard it could be the BCM, the solenoid ( anyone know where this is?), a linkage or the shift interlock. The manual doesn't tell you where these things are so can't even inspect them.
Thanks
Old 10-31-2005, 07:56 PM
Pinecajun Pinecajun is offline
Re: 2001 Aztek gear stuck in park
I work on them a lot I have seen many that have BCM problems and replacing the BCM has fixed all of them so far.
Old 12-14-2005, 08:40 PM
mapletek mapletek is offline
Cool Re: Re: 2001 Aztek gear stuck in park
i thought some cars have an interlock with the brake pedal and the gearshift out of park that is the brake has to be depressed before you can shift out of park. would turning the ignition key on and off a few times help? just a couple of things i thought of .also how much does it cost to replace a aztek bcm?i heard the 2001 and 2002 were buggy and fixed in 2003.
Old 05-28-2007, 09:34 AM
jlamson jlamson is offline
Are you still having trouble with it? When stuck in Park, will the steering wheel move in both directions, or just one. Sometimes if the vehicle is turned off before you let go of the steering wheel, I guess it binds or something, but if you relieve the pressure by moving the steering wheel while trying to shift, it will then go out of park. It happens on my '03 Aztek occasionally.
--Jim
Old 07-08-2008, 04:13 AM
amestaxi amestaxi is offline
Question Re: 2001 Aztek gear stuck in park
My 2003 aztek has this very problem drove it home on the morning of july 3rd the wife went to go to 6the store and it would not shift the following Friday morning it shifted out of park once now it won't i'm at my wits end anyone have any ideas
Old 07-08-2008, 07:00 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
There is a little gizmo called the BTSI (brake transaxle shift interlock) that is usually the culprit for this problem. It is located sorta under and towards front of shifter.
Old 03-04-2010, 01:50 PM
The Silver Goat's Avatar
The Silver Goat The Silver Goat is offline
Thanks
How did you by pass the interlock? Mines having the same problem and I took to the dealership. They repaired the wiring in the shifter triggering the transaxle inter lock (they said that's the common problem), but when we picked it up it failed when my wife went to move it out park... It's the second time I've had it in - the first time the interlock was replaced...
The last thing I need is call "I get it out of park...."
Old 01-13-2011, 12:31 PM
jimf15 jimf15 is offline
Where is the bypass? Anyone figure this out yet.
Old 06-25-2011, 10:51 PM
big dave's Avatar
big dave big dave is offline
There is a "door" in the front cup holder that pops out. The bypass is a little white detent switch. Mine had soda spilled on it from the cup holder which caused it to stick and I sprayed it with WD 40. Works okay for over a year now.
