Old 10-30-2005, 10:07 AM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
Question possible solution to my problem..
okay.. yeah Ive been having small problems with the idleing of my car at stop lights. I dont know if you read a previous thread of what happened when I was at a stop light and the car just went Vroom on its own and it lunged forward but i was holding the break hard enough.. but it still moved forward. WELL, i realized it only idles weird when the car is in operating temp. but when its cold, its good. I installed a throttle body air filter like this one
I was wondering, since it sucks up hot air from the engine since the filter sits close to all the heat, could that be a possible cause?
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 10-30-2005, 10:17 AM
Re: possible solution to my problem..
yeah.. with the city driving and the sucking of the hot hot air.. and the waiting for a red light or something sucking in hot air..?
Old 10-30-2005, 10:29 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
remove the air intake assembly and check your throttle blades, open and close them, see if they operate normally.
Old 10-30-2005, 10:30 AM
you mean see if they dont get stuck or if its hard to move them?
Old 10-30-2005, 10:34 AM
Genopsyde's Avatar
The President
yea, it'll give us a starting point on finding the issue, if they're not acting funny, it may be and electronic issue. tps perhaps or iac.
Old 10-30-2005, 10:37 AM
what can I use to lubricate, if i can, the sides of the blades, where they pivot?
Old 10-30-2005, 10:39 AM
Genopsyde's Avatar
The President
i'd just clean em with carb cleaner if they're gunked up
Old 10-30-2005, 10:46 AM
ahhh alright. SO the air cleaner doesnt affect it in any way right.. well.. other than just sucking in more air
Old 10-30-2005, 10:47 AM
Genopsyde's Avatar
The President
i can't see why it would.
Old 10-30-2005, 01:01 PM
alright, i cleaned them good.. well.. they werent bad to begin with but i gave them a good cleaning anyway.. i think it is my IAC, is there a way to check it?
Old 10-30-2005, 02:03 PM
Morley Morley is offline
Doubt it is the IAC, more like the TPS. A bad TPS can cause 1k RPM surges at idle and never throw a code.
Old 10-30-2005, 02:45 PM
i took out the IAC and cleaned it up.. it wasn't too dirty, is the tip of it suppose to be 'stuck' in the out position? cause I see a spring but I dont know if it is possible to push it in manually or it just does it while inside the TB.
Old 10-30-2005, 02:51 PM
you think that is why my car just threw itself forward like I was describing earlier?.. just a surge while I was in drive. and then I was trying to get home and I was trying to avoid something down the street so I hit WOT and the check engine light came on but just went off right away.. then after that happend, i was at a red light, in neutral, and when i went to give it gas when the light turned green and I put it in drive, it was stalling like when your learning to drive stick just abrupt stops even though I was giving it gas. That only happened for that short period of time and hasnt done that abrupt stop-go stop-go stuff anymore. well.. i havnt really driven it much lately but im sure the problem persists.
Old 10-30-2005, 03:08 PM
camaromaniac camaromaniac is offline
arent you supposed to use those cone filters with cowl hoods or does it not matter. i thought those kind of filters needed the extra air flow inside the engine bay.
Originally Posted by Rally Sport 92
Dont get me wrong though i'd love a Lt1 in my Camaro even if it had Richard Simmons strapped onto my hood naked..
Old 10-30-2005, 03:14 PM
Re: Re: possible solution to my problem..
I doubt it.. it gets more air than it does before.. you can hear it hehe and it also helped my gas mileage when i was driving it daily so i guess there is no shortage of air.
