Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 10-30-2005, 07:57 AM
77camaro's Avatar
77camaro 77camaro is offline
Angry VR Turning Off
i have a 1994 Vr commodore executive, on the odd occasion i can be driving along and suddenly the revs drop to nothing all the dash lights come on and i lose my power steering, then instead of stoping i can just put it into Neutral and turn the key and on she comes, its only happened about 3-4 times but im unsure of the problem.
Old 10-31-2005, 11:16 PM
balldrager balldrager is offline
Re: VR Turning Off
fuel pump?
Old 11-01-2005, 12:33 AM
wazza4678 wazza4678 is offline
Re: VR Turning Off
with the engine running,give the wiring harness a good wiggle at the dfi module,which is locaded directly beneath the coil packs.
if the engine stalls,report back.
this is a common problem,
but only one of many possibilities
Old 12-05-2006, 05:08 AM
holdenrocks holdenrocks is offline
Re: VR Turning Off
yea, same as my car (vr commodore 1994) .. i had enough with it .. i think its ignition coil pack or fuel pump faulty ... cos sometime i got very badly start my car ... im lucky as im "apprenticeship mechanic"
Old 12-09-2006, 01:07 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: VR Turning Off
As stated, wiring harness at the coil packs is a common fault. The fuel filter could also be dirty or the fuel pump 'pre-filter strainer' could be dirty and clogged up your pump(need a new fuel pump, $220 from Repco)
Also check the harmonic balancer has not cracked its rubbers.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 04-17-2009, 05:15 AM
reefchampion reefchampion is offline
Re: VR Turning Off
Hi, my Vn has no spark. Have changed the coil pack, crank angle sensor, computer, dfi and checked the earths. I checked the relays by swapping and trying the lights., and checked the fuses. I have one spark plug out, but still no spark. When the ignition is on, the inside fan is not working. The fan has only stopped since this trouble started. This is really strange and I wondered if any one has any other ideas on what this could be. Thanks.
Old 05-15-2009, 02:48 AM
mmcleo11's Avatar
Re: VR Turning Off
The interior fan is not working? Is your fan control on? The fan circuit is not part of the wiring loom for the engine unless than main fuse has blown, which means the car would not turn over at all.
Sure your crank pulley is not broken on the rubber?
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
