| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
turbo
alright is there any one that can tell me what id have to do to put a stock turbo from a 1991 mitsubishi eclipse into a non turbo eagle talon.
Re: turbo
next time search. Year of car also helps. Im assuming its going in to a 1g talon. your going to need the oil feed line and return. The oil pan will need to be tapped for the return line. Or you can take the one off of the eclipse and put it on there. Its a simple process but as i said if you are doing it on a 1g to 1g then you should be set. You just can't boost that high because of lack of fuel but this should help get you started. Almost forgot the water lines on the turbo will need to hook up to something that carries collant so you have some fun. Good luck
MODS , 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo and the ac still doesn't work and its been almost 3 years |
Re: turbo
dont forget charge pipes and an intercooler. the tsi manifold will bolt up, the fwd dp will fit. injectors, tb w/ elbow, bov... and the list goes on.
yea i highly suggest getting bigger injectors, becasue u will prob blow ur engine from lack of fuel. Another thing ull need is a new intake becasue ur turbo is going to change the route of your stock one, also even the stock intake wont bolt to the turbo. and yes, to go along with the kid above, the list goes on.
