Old 10-30-2005, 12:47 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
Does this clutch look bad to you? Replace or re-use??
Looks alright to me.... wondering your opinion
Old 10-30-2005, 01:18 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Does this clutch look bad to you? Replace or re-use??
Want a clutch? I also have a Pressure plate that needs to be resurfaced cause rust got on it. Let me know.
Old 11-01-2005, 01:35 AM
kjewer1 kjewer1 is offline
AF - Advisor
You can't see the thickness of the material left before you hit the rivets on the disc and you can check pressure plate warpage unless you remove the clutch. That picture doesn't give us anything to go on
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-01-2005, 08:56 AM
EDMUND65's Avatar
oh sorry, i thought you could see the thickness of hte clutch disc..
Old 11-01-2005, 08:58 AM
AF - Advisor
I can, but it doesn't mean anything. The actual thickness doesn't matter, even if I could measure it over the internet. The distance from the face of the disc to the top of the rivets will tell you how much life is left in the disc though (assuming you know what a new disc looks like in this dimension, or have a new one to compare it to).
Kevin Jewer
Old 11-01-2005, 10:08 AM
EDMUND65's Avatar
wlel i have aspace sitting right next to the car w/pressure plate... should i swap? i did a reverse burn out and totally smoked the clutch, i kno it was stupid but i had some high level of anger
Old 11-01-2005, 01:02 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
just get a new clutch and throw it on. if you spent that much time removing the transmission, then it's only smart to replace the clutch. i agree with 95GSXracer, we can't tell from that pic. just make sure when you take the clutch assembly off, you lossen the pressure plate to flywheel bolts evenly in a criss-cross pattern.
Old 11-01-2005, 02:05 PM
EDMUND65's Avatar
my problem is i have no money.... so im going to have to make due with wht i have, the tranny removal is no big deal... 40 mintues total to drop it.... and another problem im goin to have is no alignment toolll..... but tonight is when im goin tothrow everything back in
