Bought an srt4 have problems
Okay so i just bought an srt4 and was really excited but not anymore. First of all when I test drove the car it was awesome, it pulled like crazy and had no problems whatsoever. But after the purchase was made and they took the car to the back of the shop to be "cleaned" the car runs like shit.
It hesitates at idle and at speed and when you step on it more the more it hesitates like crazy and runs rough but if your easy on the pedal it seems better. Also when you drive around for quite a bit the car seems to be running much better like normal. Also i have a check engine light on consistently and when its flashing its worse and when its on all the time the car runs better. i needed this car badly for a car that has run even worse (that I traded) so im very stresed and sad right now, and if its not fixed fast enough im afraid i have to get a car somewhere else. Its a 2004 and i like it a lot. Thanks for your help. |
Re: Bought an srt4 have problems
NEVER DRIVE A CAR WITH THE CHECK ENGINE LIGHT FLASHING!!!!!!!!!!!!! get it back to the dealership asap, and demand that they give you a rental while they fix it! thats why you bought a new car
Re: Re: Bought an srt4 have problems
there can be tons of problems like that. how many miles on the car? was it new when you got it? if not, what was done to it? what have you done to it? any other problems?
cyl 3 is not a common one to have problems. number 1 has a head issue, due to an oiling problem (nothing serious, but makes an annoying ticking noise). how much boost were you running before you had the problem? i smell a boost controller, be honest! they will figure it out, or you get a new one. thats teh beauty of a new car! |
it can be if they steamcleaned the motor. that can cause problems if somthing got wet. be sure to let us know what they claim the problem was/is
hmmmm. weird. so water got into the hemi-tube, and corroded your plug/wire. that would make sense. glad it got up and running. now enjoy it
This is actually surprising in one week I get two codes and the reason I bought this car is so it would be trouble free. Go figure. ps. I know this car will drink alot of gas because its turbocharged but it seems to be drinking gas like crazy and im not even using the turbo half the time. |
on average, expect to get 20-25 miles per gallon. get teh evap system checked as well. that can cause a lot of problems
ya i plan to get it checked soon surprizingly the car runs fine so i don't think its major. Anyways Tex what year is your car and did you check the wiring harness that could be touching with your clutch pedal when its depressed I just checked mine and its rubbing a bit but its not to bad you should check yours. |
i have one of the first 03s in existance! i already fixed that wiring harness. i needed that little bit of extra clutch play
hey is their anything else that you learned about your car and how long did you have it. Is it stock and what problems if any did you have. I plan to keep this awhile and was wondering if I put mopar parts on this car if it would void my warranty. |
i have done a lot to my car. it looks nearly bone stock, but probably have 10g in it on top of the price of the car. all of the problems i have had with it are typical of hte srt. TPS sensor problems, Ticking in teh head (for the 03's, too small of an oil passage, blew my tranny, etc. all was covered by warranty, even with all of my mods)
i really enjoy the car, and its a blast to drive everyday! my mod list: AEM intake, custom 3" turbo-back exhuast, Crane 193-0012 camshafts with fidanza cam gears (soon to be Crower cams), mopar stage 1 (stage 2 is in my World Touring Car that i work with), stage 2 wastegate running 18psi, mopar stage 3 coilovers, hotchkis swaybars, dcsport strut bars, prothane bushings all around, wilwood big brake kit in front and powerslot/hawk combo in rear, 18 bronze icw wheels with 235/40/18 sumitomo tires (soon to be 245/35/18s). mopar short throw shiter, greddy turbotimer, and i know im forgetting suff! as soon as AEM gets off their butt, i am first on the list for their plug-n-play standalone computer, and that is going to be matched up with a mopar stage3 turbo assembly. this way the car looks stock, but should be pushing 400hp on pump gas |
hey what options came with the 03 04 05's. I'm a bit confused because my vin says my car is a 2004 but when I looked at the door it say it was built in 09/03. So does my car come with a limited slip? and do you have a sunroof or do the 04, and 05's have them. |
