Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-29-2005, 11:59 PM
B16Z6+S20's Avatar
B16Z6+S20 B16Z6+S20 is offline
Send a message via MSN to B16Z6+S20 Send a message via Yahoo to B16Z6+S20
cat question
if i remove the catalitic from mi 99 GSR and instal both sensors to a direct pipe in the same order, will i get a check engine? and also is there a way of removing the cat with out any complications?
Old 10-30-2005, 11:14 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: cat question
there is a resistor clip thing that you have to get. The first 02 sensor won't care, but the second one will notice that there isn't a change in emissions so it will kick a code, which might make your car run like shit.
Why are you takin the cat of in the first place??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-30-2005, 04:59 PM
B16Z6+S20's Avatar
Re: cat question
i just want to make the flow faster, for more HP
Old 10-30-2005, 07:31 PM
Schister66's Avatar
AF -Advisor
Re: cat question
well unless you have other things done i.e. Intake, header, exhaust, cams........etc, it won't really do anything
Old 10-31-2005, 01:36 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: cat question
get an o2 sim for the cel.
just keep the primary on the header and the secondary on the hi flo and you will be fine.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-31-2005, 01:42 PM
Schister66's Avatar
AF -Advisor
Re: cat question
i still think its really pointless unless you're going to be doing some other work with the removal of the cat......but that's just my
Old 10-31-2005, 01:51 PM
K2sInteg98 K2sInteg98 is offline
Re: cat question
all u need is an o2 simulator.
Old 10-31-2005, 04:58 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: cat question
you are right
hondas 3 way cats flow awesome unless your going insane N/A *i've seen 225WHP N/A running cats fine* or turbo I see no reason to touch your cat.
If your cat is dead replace it with a smog legal and highflow like I have cheaper then honda and it "flows better" look into catco random tech etc.
Old 10-31-2005, 06:02 PM
B16Z6+S20's Avatar
Re: Re: Re: cat question
Originally Posted by Ace$nyper
you are right
man if i had know it sooner i would have save a few bucks, any ways i dont know if the one i installed is smoke legal cause theres no smoke restriction down here, but its supose to be beter than the original. and one thing i noticed is that the original cat has two scren inside, one on the begining and the other at the end, and that has to restric the flow a little. any way its already done so i gues il have to live with it. thanx to all for caring.
Old 10-31-2005, 07:33 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
I know you said it is already done, but as Ace already said our cats are pretty efficient at doing what they do without losing power. I have a custom 2.5" straight pipe in place of my cat and the only difference is I can hear the VTEC engage more now than before. no real power increase. I felt a much bigger increase when I ditched my power steering and A/C.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
