Old 10-29-2005, 11:03 PM
ozzfreak ozzfreak is offline
Thermostat problem
I did a search, and couldn't find anything, so here goes. At one time I was having over heating problems, so I took my thermostat out, to help with the heat. Well, I have fixed the other problems, so I figured I'd put in a thermostat now since winter is coming on. I went to take off the cover for the thermostat, and good lord what did I do. I busted a bolt off. I think that the overheating may have warped something in that area, causing this. So, i'm wondering if I can get a replacement part that the thermostat sits in. It looked removable, not saying that it will come off either because of the over heating, but if it does. Luckily it's not leaking right now. I don't see how, but it's not. Any help would be great, thanks.
Oz
Old 10-31-2005, 08:23 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Thermostat problem
go to the dealer for that part if you want it new, junkyard for used
Team Lonely Drivers
Old 10-31-2005, 08:44 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Just take the bolt out and put a new one in, I broke one off in mine also.
