Old 10-29-2005, 10:34 PM
h22hatch91 h22hatch91 is offline
install tranny
how hard is it to install a b series tranny?? like im pretty mechanicaly inclined .....so i know what im doing if i had some instructions...but how hard would it be to do it on my own???
Old 10-30-2005, 12:37 AM
arodg25's Avatar
arodg25 arodg25 is offline
Re: install tranny
lift it up, slide it on, bolt it together including the motor mount, hook up shift linkage; starter; wiring harness; speedo cable, install drive shafts. done.
Old 10-30-2005, 12:40 AM
ok right now i have a messed up tranny in my car, the motor and bad tranny are in my car right now, im wanting to know how hard would it be to take that one out and put in a new one?????????
Old 10-30-2005, 02:39 PM
arodg25's Avatar
Re: install tranny
take off drive shafts, speedo cable, wiring harness, starter, shift linkage, unbolt tranny mounts and tranny bolts, seperate from engine block and drop down. THEN lift it up, slide it on, bolt it together including the motor mounts, hook up shift linkage; starter; wiring harness; speedo cable, install drive shafts. done.
Old 10-30-2005, 06:23 PM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
Re: install tranny
well first off do you have a B series motor or are you asking if you can just put a B series tranny on a D series motor?
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-30-2005, 09:53 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: install tranny
http://www.c-speedracing.com/howto/b...tch/clutch.php
apply it to a cable tranny if you have cable. all bseries trannies are 97% identical. if you cant figure the differences, then, take it to a shop.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-30-2005, 10:42 PM
Re: install tranny
no its a b series cable tranny to a b16 motor......
Old 10-31-2005, 10:47 AM
4thgenSIR 4thgenSIR is offline
When I had some trouble with my clutch I just pulled the engine again. It was really really tight to get the tranny off with it in the car. It prob took less than an hour to get it out ad because you've already put it in once, putting it back in is no trouble either.
Old 10-31-2005, 02:23 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: install tranny
if you were mechanically inclined then you wouldnt be asking this question.
for example i like to think of myself as being mechanically inclined but i didnt ask anybody what needs to be done when i did my first ls swap
Team Lonely Drivers
Old 10-31-2005, 02:24 PM
Re: install tranny
oh yeah so whats messed up with the tranny ?
Team Lonely Drivers
Old 11-01-2005, 12:20 AM
Re: Re: install tranny
i am sayin that if someone was to give me some instructions to do an ls swap i could do it no questions asked..............ANd looking at some of the posts u have doesnt seem like ur sooo................. "mechanically inclined" as well soo..........as far as the tranny it just blew im guessin high mileage, im not too sure bc im not sooo what u would call inclined maybe u could tell me why?????
Old 11-01-2005, 12:48 PM
Re: Re: Re: install tranny
your right, i dont even know how to turn a bolt. i guess i dont have the mechanical knowledge to help you
Team Lonely Drivers
Old 11-02-2005, 07:31 PM
rocksolidus rocksolidus is offline
so i'm guessing what you want is somebody to show you some detailed pictures and instructions on how to specifically swap your transmission?
read up on it, thats the only way your going to find information on the internet. utilize your search engines like google if you need to. sorry i can't spend time to chart out your workload, but i hope you'll figure it out eventually.
Old 11-02-2005, 11:12 PM
Kven's Avatar
Kven Kven is offline
Re: install tranny
its pretty straight forward; just takes some time.
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-02-2005, 11:26 PM
AF - Advisor
Re: install tranny
