Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-29-2005, 10:22 PM
aukster aukster is offline
noise in cab
I am having noise inside the cab that sounds like it is comng from the passenger side near the dash or inside the dash or in that general area. Sounds like a piece of plastic hitting against something. I have a 95 Jimmy. Does anybody else have the same thing going on? Buddy of mine just recently bought a 95 jimmy and has the same noise. We are trying to figure out where it is coming from. Any help would be greatful.
Thanks
Auk
Old 10-29-2005, 10:52 PM
drdd's Avatar
drdd drdd is offline
Re: noise in cab
try ...
http://www.automotiveforums.com/vbul...d.php?t=302656
Thanks
Auk
Old 10-29-2005, 11:53 PM
Chevy454man Chevy454man is offline
Re: noise in cab
there are some problems with hood hinge bolts//they would cause all sorts of noise-when does this noise occur? over bumps? can you duplicate it while stopped and bounce vehicle?
Old 10-30-2005, 12:08 AM
drdd's Avatar
Re: noise in cab
also, check your plastic hood cowl for cracks or splits or the foam insulator breaking free at the ends of the cowl ...
Thanks
Auk
Old 10-30-2005, 06:58 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Also look if your passenger door is sagging (hinge and bushings) If so when you hit bumpes the bushings can sound like the hood issue...
