Old 10-29-2005, 09:31 PM
guy6189 guy6189 is offline
Unhappy 93 metro vehicle speed sensor
Hello does anyone know where the speed sensor is, also does anyone know where someone can get a diagram of where all the sensors are located.
thanks for your help
guy
Also I will add from reading here this is a manual trany 5 speed also the code it is giving is 24 any help would be great.
Old 10-30-2005, 04:15 AM
Tominator2000 Tominator2000 is offline
The speed sensor is made into the back of the instrument cluster where the speedometer cable attaches.
Most probably the trouble os at the end of the cable that goes into the tranny. Pull back the protective rubber boot. There should be a clip that holds the cable to the transmission. You can remove it with a small screwdriver. Pull the cable from the tranny. Notice there is a tab on the end of the cable. It is supposed to engage a slot in the drive assembly.
Bet the tab is not engaging the drive.
