mercury mystique Torque specs!!!
hi
im looking for torque specs for the conneecting rod bearings thanks its a 1997 4cyl |
Straight from my Ford Contour/Mercury Mystique service manual.
After the connecting rod bearings have been fitted, clean and apply a light coat of Engine Assembly Lubricant D9AZ-19579-D or equivalent meeting Ford specification ESR-M99C80-A to the journal and connecting rod bearings. Install the connecting rod cap. Tighten the new torque-to-yield connecting rod cap bolts alternately in several passes to 35 N*m (26 lb*ft). Rotate connecting rod bolts an additional 85-95 degrees. If you have any other questions, check out the "REAL" Contour/Mystique forum. www.contour.org.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
