Old 10-29-2005, 03:11 PM
cavyboy23 cavyboy23 is offline
Send a message via AIM to cavyboy23
Question overheating problems
my 99 cavy is acting up its been running fun and all the sudden i seen smoke comming from the engine i turend the car off and it was my coolent smoking out the oveflow and then i realized my fan aint kicking on soo my motor is getting way to hott and i have kno idea of what to do is there liek a sensor or something ?
Old 10-29-2005, 04:13 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
the ONLY time your fan should kick on is when your car is sitting in the same spot for more then 5-10 minutes, it shouldnt kick on during regular driving, its probably your thermostat ($6)
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 10-29-2005, 05:30 PM
yah i kno that but it doesnt kick on even when its sitting for over a half hour and i just changed my thermostat today and its still doing the same thing
Old 10-29-2005, 06:13 PM
colinlesser colinlesser is offline
Send a message via Yahoo to colinlesser
Re: overheating problems
your fan motor probably pooped itself out, go to a junk yard and get another, at worst youll have a backup fan when it actually does pooop
Old 10-29-2005, 06:17 PM
after looking through my haynes manual i found this, theres a such thing as a "coolant temperature sensor" i would assume your computer uses this to determine when to turn the radiator fan on and off, if its bad the computer wont get the singal, hence, it wont turn on the fan (i think) anyways, to remove the sensor, it says to release the locking tab, unplug the electrical connector, then carefully unscrew the sensor, you said its a 99, if its a 2.2 the sensor is installed in the coolant bypass pipe at the right front corner of the clyinder head, near the alternator, if its a 2.4 its located on the thermostat housing cover, hopefully this helps
Old 11-03-2005, 12:25 PM
thanks man it helped alot and now its finnally running right thanks alot
Old 11-03-2005, 12:31 PM
I bet you have a bad head gasket now, do a oil change look for contamination
Old 11-04-2005, 04:45 PM
Xx ReasoN xX's Avatar
Xx ReasoN xX Xx ReasoN xX is offline
Send a message via AIM to Xx ReasoN xX
Re: Re: overheating problems
try rewirering your fan to the ignintion fuse that way the second you turn on your car the fan will start up, i did that and my overheating problems are over.
Old 11-04-2005, 06:24 PM
i think he already got it
Old 11-07-2005, 10:53 AM
AssDust AssDust is offline
basically take the fan off, and hook it directly to a battery with 2 wires, if it runs, its good. If not, its toast get a new one or used. If it runs, its your sensor. Replace
