Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-29-2005, 02:51 PM
B16Z6+S20's Avatar
B16Z6+S20 B16Z6+S20 is offline
Send a message via MSN to B16Z6+S20 Send a message via Yahoo to B16Z6+S20
O2 sensor problem
hello guys! need a little help with the o2 sensor, i dont know where to conect the wire for the mixture gauge on a 99 GS-R two door, i have an autometer mixture gauge and has only 3 wires red, black and purple, i know the purple is the one to conect to the O2 sensor, but there are 2 sensors and only 1 wire, so wich one is it? or is there a way to conecit to the ECU? its a P72 by the way.
Old 10-30-2005, 05:03 PM
B16Z6+S20's Avatar
Re: O2 sensor problem
c'mon guys a little help please!
Old 10-30-2005, 09:45 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
pin d7. primary o2 sensor. white wire.
the one between knock sensor(red D6) and iat (brown D8).
PS: an AF gauge wired into the o2 signal is really, not worth the money.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 10-31-2005, 01:25 PM
B16Z6+S20's Avatar
thanx guys! already solve the problem, instaled a hi flow cat this morning, now if any 1 can tell me where to conect the wire of a mixture gauge to the ecu will be great.
Old 10-31-2005, 01:31 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Im proud of you....i wouldn't touch anything electrical. I'm electronically challenged.
Me w/ technology=
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-31-2005, 01:32 PM
AF - Advisor
Re: Re: O2 sensor problem
replug the old o2 sensor into the hi flo. as for the signal wire (mixture) of the primary, it is explained above.
Old 10-31-2005, 06:22 PM
B16Z6+S20's Avatar
sorry about the last post, i mixed the thread. but why is the A/F not worth the money? and i already tryed the D7 pin and it didnt work.
Old 11-01-2005, 02:30 AM
AF - Advisor
well if its not D7, then its got to be A6. just too many damn wiring for one mind to hold. its clouded sometimes. if its not A6, then i dont know what else to tell you.
a narrowband AF gauge will only give you a light show. it is at least useful for telling you when your PO2 has crapped out on you. other than that, if your looking for an accurate way to see your AFRs, use a wideband.
