Old 05-24-2002, 03:43 PM
CRX586's Avatar
CRX586 CRX586 is offline
tie/sway bars
Do people use tie bars and sway bars on the same car, or is it more like choose one and you don't really need the other?
Old 05-24-2002, 04:39 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
they can be used on the same car, usually sway bars are only for the tops of the shocks and ties are for the lower rear area, while sway bars go front upper, and rear upper.
most peeps use both.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-24-2002, 06:04 PM
CRX586's Avatar
Alright, say I only have money (for now) to put 2 on - which areas would benefit me the most? I was thinking front/rear upper...
Old 05-24-2002, 07:06 PM
Bleebdat Bleebdat is offline
Send a message via AIM to Bleebdat Send a message via Yahoo to Bleebdat
Sway bars are on the bottom of the strut and actually are connected to your control arms. Tie bars arent worth their money, get front and rear strut bars first, then get both sways, then get the tie bars, and somewhere in this mix you should upgrade springs, struts, and tires.
Old 05-24-2002, 08:17 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
crx si sway bar
You can use the sway bar from a si crx on your car, you'll need the mounting brackets and the lower control arms from the donor car as well.
