Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-29-2005, 12:58 PM
tuffluck tuffluck is offline
1991 corolla fuel filter replace
i don't have any clue where the fuel filter is on this car, but if i did, i'd replace it. any clues?
Old 10-29-2005, 08:23 PM
Diblue Diblue is offline
The fuel filter on my 91 toyota corolla AFE engine, is right behind the air filter hose in the engine compartment. To replace it, pop the cap off the gas tank...as if you were gonna fill it up, to relieve the pressure.
For fuel-injected (which I'm gonna guess yours is)
1. Loosen the banjo fitting bolts on both ends of the filter (will probably need a back-up wrench on the fitting at the filter) and disconnect both ends.
2. Remove the bracket bolts from the inner fender and remove the filter assembly from the support bracket.
3. Install the new filter and tighten the bracket bolts securely. Make sure the filter is installed with the outlet facing up.
4. Suggests using new sealing washers-two per banjo fitting-install the banjo fittings and tighten the bolts.
5. The rest is the reverse of the removal. and of course, check for leaks.
Old 10-30-2005, 12:08 PM
thanks! that sounds easy enough.
Old 10-30-2005, 01:13 PM
Re: 1991 corolla fuel filter replace
np, it is a very easy procedure. I pulled those instructions out of my Haynes manual for ya.
