| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Tamiya gloss paints
Hi,
I just bought myself a harder and steenbeck evolution airbrush and have trued to airbrush some amiya acrylics because i heard so much good about them. But i just can't make the gloss colours glossy.. they always dry matt. i used Isopropanol to thin the paint and i've tryed spraying the paint un thinned unto a ratio to 50% pain50% alcohol.. and still it dries matt. Does anybody has an ID of what I'm doeing wrong? I used a tamiya primer and my airbrush pressure is 2bar... that's what the discribtion of my airbrush mentioned for the ideale presure.. thx in advance. |
Re: Tamiya gloss paints
If it's dull, it's usually because you thin too much the paint. (or because you have a rough finish)
2 bar is near 30psi right ? if so, it's a bit too much for my taste. I work between 7 and 20PSI
![]() CarsModeling.com. My Scale Model Cars blog. |
but if I thin it less... it becomes verry rough... i've heard about some people who spray tamiya paints unthinned!! but then it's like sandpaper-rough
How far from the surface are you spraying?
What colors are you spraying?
I've tryed from spraying from 5cm to 20cm (that's 2 to 8 inches)
I've tryed the gloss bleu.. (don't remember wich) and the clear... |
Can you post a photo of the finish you're getting?
srry I can't post a pic, but it's a lot of different kinds of matt.. in 1 place there soms gloss but with masses of orange peel.... way po much to wetsand it out.
Sounds like you're not spraying constently, and that you're spraying from too far from the surface.
Orange peel could also indicate the paints too thick. Have you tried thinning the paint with Tamiya acrylic thinner?
no i've just used the alcohol and water.. but would it make THAT much of a difference?
Yes, especially water, you should never thin acrylics with water.
ok then.. tomorrow I will look for the tamiya tinner.. I hope it's the solution because i really like the acrylics for the easy clean up.. just soapwater and alcohol... easy an non-toxic... BTW is there a Taimya laquer thinner?
Tamiya only makes lacquers in spray cans so they don't produce a thinner, they do produce a thinner for their acrylic and enamel ranges though.
Re: Re: Tamiya gloss paints
http://www.modelsforsale.com/catalog...ucts_id=111922 Its been out awhile actually. Cheers Farrokh
Current Projects Yamaha YZF-R1 Taira 70% complete Lamborghini Diablo SE30 (Fujimi/Revell combi) 20% complete Tamiya Ferrari Enzo plus SMS, Sakatsu and Acustion 10% complete. |
Re: Re: Re: Tamiya gloss paints
great.. I like laquers a lot for carbody's but the spraycans are just so damn expensive..so if I can decatnt them... it would be a big money saver. THX for alle the afvise ...just need to find those thinners yet...
