Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-29-2005, 09:09 AM
hellfirea18 hellfirea18 is offline
Red face head unit reseting itself
ok, I know how to enter a code on my stock system, so I don't need help with that. getting pretty good at it too. I have a 2002 eclipse gt, and the head unit keeps going haywire and reseting itself, and then it goes to CODE. has anyone had this problem, or know what might cause it? any help is appreciated! thanks
Old 10-29-2005, 09:13 AM
alphalanos alphalanos is offline
check all your grounds. like battey negative, and also check all the wiring for the radio.
96 EJ6. Future home of boosted B18C1.
Old 10-30-2005, 12:48 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: head unit reseting itself
agreed. it sounds like the headunit keeps losing power. make sure its grounded correctly and that the power wires are connected securly.
Old 10-31-2005, 11:12 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Is it just your head unit losing power, or does your clock also reset. If it does than your batter is probably shot (that should have been obvious because you would have kept having to jump your car)
Old 11-09-2005, 09:01 AM
thanks. checked all the wiring. seeems fine now. I got rid of the stock battery and put my red top battery in. everything is better now.
