Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 10-29-2005, 08:01 AM
Fleapit Fleapit is offline
Question VW bora brake pedal travel
Hi all, changed the offside rear brake flexi-pipe assembly on my bora (between rigid pipe and caliper) due to a fluid leak which emptied the reservoir.
Bled brake system conventionally and got out any air.
The problem is this..although the brakes work, the pedal has free play to about half its downward travel before any braking comes into effect with engine on. (With engine off pedal goes solid when pumping as you would expect.)
Thought at first there must have stiil been air in system so bled again..no change.
Any thoughts? What am I missing? Is there any adjustment on the pedal/servo/master cylinder on this car?
Old 10-29-2005, 09:25 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
There is still air in the system if the pedal goes down 1/2 way with engine off
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 10-30-2005, 05:38 AM
Re: VW bora brake pedal travel
No, with engine off the pedal goes solid at the top of its travel.
Old 09-15-2007, 09:27 AM
stumac stumac is offline
i have just had the same problem with my bora. but i bled the two bleed nipples on top of the master cylinder first , then i went round the wheels again.and it worked .
